Moved needle
  • anokES
    • Aug 2012
    • 206
    Moved needle
    I moved my gas needle while I was changing out my cluster lights and put it back without realizing. I only need to adjust it slightly, however it really bugs me. Is there any way I can remove the reset pin to adjust or I'm I just stuck with removing the cluster to move it?
  • AndrewBird
    The Mad Scientist
    • 11898
    You are stuck with pulling the cluster. If you can, remove the lens and re-install the cluster without it. Then you can check it in the car to make sure it is correct without having to pull it out multiple times. Then just put the lens back on and put everything back.
