A couple of days ago i realized i was a little low on coolant after driving around for a bit. So i topped off the overflow tank. Then I let my car run for a bit when I went inside. Then I came back out about 5 minutes later and my car had turned off. I started it up and it ran like shit and sounded like a diesel truck. It shut off after about 30 seconds. Also my cluster is fucked because the temp and gas gaugs don't work. I then added some gas to make sure I hadn't run out. Then I tried to start it again and it wouldn't start. It would crank and sounds like its gonna start but it doesn't. This makes me think its the starter but that doesn't make sense because it ran lik crap when I had got it started. Any suggestions? Thanks in advance.
87 325is Won't start help!
