Still have the right-turn grinding noise...
  • Victor_PR
    • Jun 2011
    • 296
    Hi everyone;
    About 2 months ago I posted describing a grinding noise I get from the rear of my car when I make right turns. At that time my CV axle boots were shot so I temporarily injected grease into them and wrapped in duct tape - a temp fix recommended by another board member. Well, the temp fix was until I could fund the CV axle replacement which I did. At that moment I also replaced my Center Bearing which was totally shot. Well, the grinding noise continued so the next thing I tackled was rear wheel bearing replacement which I did with my son last week. Result; still have the grinding noise.
    Any thoughts as to where my problem might be? Things I haven't replaced are: 1) Upper shock mounts, 2) Differential, 3) Shocks, 4) Sub-frame bushings.
    Thanks in advance for the help!
    Victor
    Rides...
    E30 325i - 1990
    F30 328i - 2014 (DD)
    F25 X3 - 2016 (Family car)
    1974 - 2002 (The ruler of the stable) SOLD
  • dnguyen1963
    • Nov 2011
    • 2651
    The brake calipers are often overlooked. Check to see if they are stuck and cause the grinding noise.
    • blunttech
      • 12850
      Dump the rear diff fluid and replace with redline or add an LSD additive
      sales@blunttech.com
      www.blunttech.com
      Like us on Facebook
