91 318i m20 swap help
  • shayne_bermudez
    • Nov 2013
    • 78
    I want to swap a m20 into me 318I ..relized it will make more power down the road.....I want to know all the parts I need and the cheapest way on doing this. I would like to reuse as many parts as possible .basicly what can I reuse and what do I need to buy
    E30s for life. will drive nothing else than a BMW.
  • Hooffenstein HD
    • Nov 2012
    • 1388
    Sell it and buy a 325i.
    • cabin
      • Dec 2006
      • 552
      Why? Especially if he has a good shell to start with. Not like it's an overly expensive or complicated swap.
      As far as the swap goes, there's not much if anything you can reuse. Maybe the radiator and differential. You're basically swapping the entire drivetrain here.
      -Justin
      Current: BMWless for now... '15 Grand Cherokee & '03 Mach 1
      • Hooffenstein HD
        • Nov 2012
        • 1388
        Understood. It's pretty much bolt in and plug and play if you get the right loom/ecu (maybe you'll have issues with pin 20 on the c101) but generally with the way these threads go is; if you have to ask, it's beyond your abilities.
        EDIT:
        Also, there really isn't much of your old engine/driveline set up you can reuse; maybe the radiator if you want the cleaner look. You'll need pretty much the entire driveline from a 325i. Drive shaft, gearbox, shifter, exhaust, engine, engine mounts, ecu, loom, afm etc. Unless you search for the deals, or get a decently priced complete conversion, you may well have been better off just selling the 318i and getting a 325i.
        • shayne_bermudez
          • Nov 2013
          • 78
          EDIT:
          i have done swaps before but i wat to use the tranny from my m42 because its a 5 speed and the one off the m20 is auto. ik it will sit a little off but idc as long as it works. should i use the driveshaft off the m42 or the m20?
          • ccsdo5
            • Mar 2013
            • 708
            I don't think the getrag 240 transmission on the M42 will bolt up to the M20. You're probably better just getting a getrag 260 and I think you'll need a manual 325i drive shaft.
            -Dee
            5-lugged turbo 318is Barn car
            IG: @deebelmont
