Yes i know, another rough idle post. Bmw 325i e30
  • BANSHI
    • Dec 2013
    • 17
    91 325i e30 automatic. I checked the ECU codes and I'm throwing the code 1444 which means everything's okay.
    On cold startup it idles around 600 to 750 somewhat okay, but the engine is shaking to shit. Also when accelerating it seems to lose power for a second then speeds up, but it takes a while for it to switch gears, so when cruising at 20 miles per hour the rpms are at 2500 or higher.
    When it warms up to its operating temperature the idle smooths out, but still slightly feels like its still bogging down. Also it seems to switch gears sooner.
  • EyExR
    • Jan 2011
    • 959
    check your spark plugs....
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    • Freakshow
      • Apr 2013
      • 174
      Check your ICV give it a good clean and see if it helped.
