Fuel pressure at shut-off
  • LateFan
    • May 2013
    • 4436
    '86 325es.
    Installed a new FPR, starts right up, fuel pressure is steady 31-32 psi.
    At shut-off, it maintains pressure in the 30s for an hour or so, starts dropping, and the next day it's 0 to 5 psi.
    Does this mean the check valve in the pressure pump is going?
    Thanks -
  • atldohc
    • Nov 2008
    • 359
    if you have no external leaks then yes. either that, the fpr, or a fuel injector might have a small leak.
    • LateFan
      • May 2013
      • 4436
      Rebuilt injectors, new FPR, no leaks.
      Ordering a new pump.
      Thanks!
