Air Box Drilling?
  • e304me
    • Feb 2006
    • 1374
    Originally posted by Rob
    and you're motor will probably have a nasty lean spike. Mine did on the dyno.
    Do you know the reasoning behind this?
    • 2002maniac
      • 4260
      DId you do a before/after dyno? The lean spike might have been there all along...
      • James Crivellone
        Head Janitor
        • 6301
        Originally posted by rwh11385
        you lose horsepower
        you lose mpg
        but it does sound good for free
        Do you have dyno results to prove this? I've seen both before and after and the difference is around .4 hp
        • rwh11385
          lance_entities
          • 18403
          DuButt Dyno. But it pulls much better without sucking in hot engine bay air.
          Somehow even if you are speaking the truth, I believe there is a big difference between an open hood with a fan on the front of your car and then stop and go traffic and a closed hood....
          • Rob
            • 8166
            ventilated lower airbox=lean spike
            stock solid lower airbox=no lean spike
            swapped it on the dyno
            no I dont have the graphs.
            BEERTECH
            • e304me
              • Feb 2006
              • 1374
              which one did you do first? maybe more air was comming in the the drilled box and made it run leaner or something? i dunno
              • Rob
                • 8166
                that is most likely the case, but who cares? it sounded cool!
                BEERTECH
                • e304me
                  • Feb 2006
                  • 1374
                  well i would think the engine would adapt and return to running normally after some driving with the drilled
                  • rwh11385
                    lance_entities
                    • 18403
                    if I take out my chip and put in my drilled box, i can drive with none of the extra horsepower and all of the fuh raze sounds....! and run 87 octane~! (m50 injectors will make it run perfect too!!!~`!)
                    • -Javier-
                      • May 2007
                      • 382
                      nice
