momo wheel question
  • KillerCalypso
    • Jan 2004
    • 459
    momo wheel question
    I went home this weekend and took off the stock airbag wheel (forsale by the way) and put on a momo fighter i got for christmas, although i did run into problems. I cranked the bolt down and i still have play in the wheel. Maybe i dont have it on correctly but i think i do, i can move it back and forth (pull towards me and push towads the instrument cluster) about 1/2 an inch, there is also a very slight play left to right. Maybe someone could give me a few pointers.
    Is there a spacer between the column and the hub that im missing? Or, did i just need to push it in hard?
    Any info would be awesome
    andy
  • Beej '86 325es
    • 2639
    There should be a MOMO adapter specifically for the E30 that you need. I think they usually go for about $40 or $50
    -Brandon
    '86 325es S50
    '12 VW GTI Autobahn DSG
    '03 540i M-Sport (sold)
    '08 Jeep SRT-8 (sold)
    For sale:
    S50 TMS chip for Schricks
    • KillerCalypso
      • Jan 2004
      • 459
      i have the correct momo adapter, its bolted down and everything but there is still some play between the hub and the column....
      • cramer
        • 1812
        I take it you have/had an airbag? The spline is different for airbag cars and needs to have a spacer (or washers) installed to eliminate the gap and allow the nut to tightened down the wheel properly.
        Chris
        90 Corrado/91 M3/01 M5
        • KillerCalypso
          • Jan 2004
          • 459
          ahh this makes sense now...I did have an airbag and the bug didnt come with any spacer/washer to eliminate gap. I take it ill have to ask the people at momo about it unless anyone has done their own?
          thanks for the info
          • Rob
            • 8166
            I had the same problem. 2-3 thick washers from home depot did the trick...
            BEERTECH
            • KillerCalypso
              • Jan 2004
              • 459
              thanks for the help rob
