So every now and again as of late the power in my car will cut out past 2000 rpm if I'm in a higher gear like third or fourth. My external fuel pump has been making a lot of noise which I think might be the cause. It happens intermittently and only when I'm in the higher rpms and the power will just cut when it gets bad the revs just don't go up and the engine is still running. I tried replacing the fuel pump today but after I tried starting it the pump itself started pouring out fuel. So after putting the old pump back in im still having the problem. Any ideas?
Sent from my SCH-I605 using Tapatalk
