318i m20 engine swap help??
  • Inxcesof
    • 33
    I am transplanting a m20 into my 84 318i. I have the engine tranny suspension and exhaust on. I am trying to wire the 2 harnesses together does anyone have the colour codes for the 318i?.I have them for the 2.5. I had one posted for me on another forum but it is gone now. I only need the colours from the connector beside the fuse box.
    thanks
  • rs4pro3
    • 5808
    I've made a plug to do this swap so if you need any help feel free to ask.
    85 325e 2.7 ITB'd stroker
    • Inxcesof
      • 33
      what i need is the colour to colour ( from the m10 to m20 plugs) I have 80% of them connected but I lost my diagram. So i need like black- black, green -brown. So I know what to soulder together.
      thanks alot
      the link does not work BTW
      • Schnell 318
        • 567
        Originally posted by rs4pro3
        http://pws.prserv.net/usinet.wdroll/c101-1.htm
        so the motor is plug and play with that?
        • rs4pro3
          • 5808
          IT should be. It was made to go from an 85 318i chassis to a 325i Engine, you'd need to wire in a couple wires like the tach single(Fred has a write up on this). I cut up a couple Engine harness and what not so it will just plug into the 318i fues box then the 325i wiring harness will plug into it.
          I'll post the wire-wire scheme latter today.
          • Inxcesof
            • 33
            thanks alot
            Jase
            • Inxcesof
              • 33
              Did you get a chance to find that wiring diagram?
              • rs4pro3
                • 5808
                Ya
                Ok This is From The Engine side of the plug on the 318i to the Chassis side of the plug on a 325i Engine.
                318i-325i
                White/Blue-White/Blue
                Blue/White-Violet/green
                Brown/green-Black/Brown
                Brown-Brown
                Violet/green-Violet/red(both large guage)
                Blue-Blue
                Blue/Violet-Blue/yellow
                Green/yellow-Green/yellow(both large guage)
                Greeb-Green(both large guage)
                Black/yellow-Black/yellow and (smallguage) black/green
                Left on the 325i side You'll have a Yellow/White wire(Fuel rate ouput)
                Black(Engine speed output)
                Brown/black(Check Engine light)
                Plus some other wires but I never found there functions.
                I never tested this plug and made the conections based on the Feature that wire did and not it's color.
                • Inxcesof
                  • 33
                  I will give this a shot and post how it went..Thanks again
                  Jase
                  • rs4pro3
                    • 5808
                    No prob, keep us updated and remeber what side of the plug I gave the wiring color from as sometimes the wiring color changes after the plug.
                    • Inxcesof
                      • 33
                      Yes I ran into that already. I am hoping I can still get the gauges to work including the feul milage gauge. Some of the other wires are to things my car dosent have.
                      Jase
