Instrument Cluster (Help)
  • aaron_silva
    • 1785
    Is this the grounding screw that needs tightening? My fuel gauge has been wacky for way too long and I took out the cluster. I want to make sure that this is the correct screw to check before I re-install the cluster.
    Quick responses would be great.
    TIA
    Aaron
  • e304lyfe
    • 807
    that is the screw people speak of...
    • aaron_silva
      • 1785
      Great! Thank you so much.
      Aaron
      • aaron_silva
        • 1785
        That didnt do the trick. I guess I will be looking at a new fuel sender.
        • BavarianBimmer
          • 951
          Don't you have a bad connection under the backseat ( sender unit )
          check this before you get a new one
          1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
          1997 E36 328iT
          1990 E30 325iT 24v SOLD
          1989 E30 325i 2.7i M-Technic II SOLD
          • aaron_silva
            • 1785
            Thanks for the suggestion. I will do that before I buy a new one.
            Thanks
            Aaron
