Installed New Starter, Car Started Once, Wont Start Back Up HELPPPPP
  • 1E301
    • 176
    FIXED.
    If anybody has advice or if this has happened to them, LET ME KNOW ASAP!
  • MyE30
    • Sep 2013
    • 326
    So you are sure none of the two power wires to you starter are grounding out on the starter itself?
    • 1E301
      • 176
      I will double check this in the morning
      • 1E301
        • 176
        Update**** bought new fusible link and still no good.... Going to have starter replaced AGAIN since this one is most likely faulty. I'll update with results Saturday. If anybody else has insight on the problem please let me know. Thanks.
        • mr.vang
          • 4371
          Did you unhook the battery before replacing the starter?
          • M-technik-3
            • 18946
            Are the battery terminals tight? Or is the battery old? Did you install it or did someone else?
            • AndrewBird
              The Mad Scientist
              • 11898
              How about the engine ground strap?
              • 1E301
                • 176
                Yes battery was unhooked. Yes battery terminals are on right. Even swapped out a battery an tried it. Still no good. Will check engine ground strap next.
                • 1E301
                  • 176
                  You're a genius haha. Car now runs! Stupid ground strap
