Aftermarket steering wheel install Airbag car
  • OOMPH!
    • 3487
    I have a momo steering wheel and I have a airbag steering wheel. I heard that I might run into problems making the horn work because of this. Does anyone have any suggestions or already installed an aftermarket wheel on an airbag model?
    THanks
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Ditch the airbag altogether
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • asubimmer
      • 6482
      my horn works fine and its really pretty easy to install. Make sure you get some washers or something to make the wheel firm
      • OOMPH!
        • 3487
        Oh ok, did you use the momo hub and washers as well? I have the momo hub part 2006.
        • asubimmer
          • 6482
          yep
          • m42technic
            • 1056
            You need the remove the white plastic piece from the column, and stack wahers under the nut that holds the wheel on, as the threads dont go far down enough.
            James Peacock
            WWFSMD?
