Long time listener, first time caller. A little new to working on cars, pretty good with 2 stroke scooters,
I need some help please.
1989 325ix
217000 KMS /135000 Miles
5 Speed
The problem: The car runs rich @ idle + gets overall crappy fuel Economy. 6kms / L or 14mpg.
notes:
Question is what am I missing on this list of things to validate:
Check /replace AFM
Clean ICV
Check Thermostat
Check for vacuum leak from Throttle body to intake Manifold
Advice / opinions welcomed and encouraged.
Cheers, Brett.
1989 325ix
5 Speed
notes:
- Idle is wobbly when the engine is cold 500-1000 Rpm, When warm it is stable at about 600 Rpm.
- The Fuel Economy Gauge maxes out at Idle and in 1st gear but operates properly when driving through the other gears. *It Seems to function properly but this has not been tested
- Recent fixes include: New O2 Sensor, new coolant temp sensor, new fuel pump, new gas tank, New plugs, Cap and rotor, fuel and air filters are new. No gas in the oil or tailpipe. new coolant.
- It has been cold here but I park inside during the day and the wobbly idle exists at different air temps. (-20c to +15c)
- I also have no heat, something is up with the core I suspect but have not had time to sort that and I have no idea if the 2 things could be related.**Opinions welcome here!
Check /replace AFM
Clean ICV
Check Thermostat
Cheers, Brett.
