Starting problems, any idea?
  • jrockbk
    • Jun 2013
    • 369
    After parking my car overnight the past couple of days I have had a really hard time getting it to start. The symptoms are, I get in the car and turn the key and it just clicks. After taking the key out and putting it back in to turn the ignition a few times then it will start. Today took the longest to start but once it's up and running I can turn car off and it starts up the first time. This is only a problem after it sits for more than 6 hours. The car is a s50 swap car, I'm in NYC and it's been snowing a lot lately and I've been driving in the mess. Could this be my starter going bad? Or is it freezing overnight? Could this be fixed or should I buy a new one? Should I look at something else like the ignition switch going bad? I really don't know why this happens.
  • jrockbk
    • Jun 2013
    • 369
    Nobody?
    • vpilarrt
      • Jun 2006
      • 2096
      Things to look at first: starter, ignition switch, battery.
      • jalopi
        • 2370
        If you can hear the starter relay clicking every time you turn the key then it's most likely not the ignition switch. Make sure the battery's good (put a meter on it and watch the voltage drop while someone cranks it. Not exactly the best way to test for a bad battery, but if it drops below 9-10V then it's probably the battery) and if it's not the battery then it's probably the starter. Before you just buy a new one though Autozone and other parts stores will test the starter -or- battery for free.
        • jrockbk
          • Jun 2013
          • 369
          Battery is brand new got it one month ago so it's prob the starter going bad?
          • dirtbag30
            • Apr 2013
            • 678
            bad ground, loose connection, and cold weather kills CCA on a battery. if you bought a crap battery from walmart i wouldn't hesitate to test it. ive seen new batteries fail before.
            i have no idea what i am doing with my life
            • jrockbk
              • Jun 2013
              • 369
              I'm thinking it may be a rotten ground strap to the starter, or the ignition switch because I have a brand new battery from autozone and the power is there, I replaced the battery because of the cold killing the charge. And if it was the battery shouldn't I need to jump start the car? Also wouldn't it just crank underpowered or rapidly click? And that doesn't happen. Now sometimes when I stop the car I have to turn the ignition a couple of times b4 it will start and no click when key turns without a start
              • dirtbag30
                • Apr 2013
                • 678
                yes i guess if it was the battery it wouldnt end up starting at all. try cleaning up the ground.
                • jrockbk
                  • Jun 2013
                  • 369
                  Replaced starter problem solved
