Is there a way to keep the wipers from being activated when I use the windshield washers? It always wipes more than I want and I would rather just activate the wipers manually. Any ideas?
Want: "independent wash"
Looks like you can probably just unpin the washer pump ground wires from the power distribution box where they connect to the wiper control unit (Brown/Black, terminal 85).
.....or, for something more convenient and permanent, you could pull out the wiper control unit and break off terminal 851989 Bronzit 325i
Originally posted by jperris View PostLooks like you can probably just unpin the washer pump ground wires from the power distribution box where they connect to the wiper control unit (Brown/Black, terminal 85).
.....or, for something more convenient and permanent, you could pull out the wiper control unit and break off terminal 85Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
You could just pull the stalk quickly a few times to spray without activating the wipers, then push down on it to use the manual wiper operation.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
I'm always a fan of things that don't remove original functionality. I can say that occasionally wiping a dry windshield won't hurt the wipers that much.Interested in vintage cars? Ever thought about racing one? Info, photos, videos, and more can be found at www.michaelsvintageracing.com!
you could also run a separate switch grounding the Brn/Blk wire at the pump and install a doide in the return wire to the module so it doesnt ground pin 85 and it will run the pump and not trigger the timer on the module(normal stalk function would still work), a lot of work i know but there is always a solution .i just agree with above posts just letting wipers run is easier......Angus
88 E30M3 X2
89 325IX
92 R100GS/PD
