Upgrade injectors?
  • christophbmw
    • Mar 2004
    • 363
    Upgrade injectors?
    Hey i was wondering what a good fuel injector uprade would be for my M42. I just found out my #2 injector isnt firing right making my engine run lean. I have a stock one coming and it will be here later today, i am planning on putting a mark D chip in sometime and was wondering if i could see any gain by putting bigger injectors in since now would be the time to do it....thanks.
    '91 318is
  • kowalski
    • Jan 2005
    • 1791
    19 lb ford mustang injectors. make sure they're the 4 pintle ones tho, you will also need some tuning after the install to get them to deliver perfectly.
    • christophbmw
      • Mar 2004
      • 363
      thanks.....what kind of HP gains will i see W/ proper tuning? Im still trying to decide if it will be worth it.
      '91 318is
      • MrK
        • Jan 2006
        • 709
        Gains with JUST injectors? That'll be a first. You WILL notice gains though, since as you said your stock injectors were faltering, but hp gains OVER stock will only be realized if you combine the bigger injectors with other things... too lazy to go into more detail, sorry :D
        Edit: OOOOOPS... forgot about the MarkD chip :D If you're getting one specifically for 19lbs injectors, then there will be some gain.
        This is your M20 on steroids:
