No starts, drives, jerks then dies
  • LagunaSecaBlue
    • Sep 2013
    • 360
    My girlfriends E30 is having some problems. She was pulling into the neighborhood and it was jerking really bad. I came to meet her because she tried leaving and it died. I started messing with it, started up went to drive it sputtered and jerked short and heavily then died. Now it wont start.
    Main Relay?
    #AZE30
    1991 318i
    1989 325i
    1989 335i
  • E30_Pare
    • 7801
    sounds like the fuel pump died.
    DREWLIENTE
    1$ PShops PM me
    • Chessmaster
      • Jun 2012
      • 501
      also check your cps. does it turn over/crank?
      • LagunaSecaBlue
        • Sep 2013
        • 360
        I will check fuel pump.
        It does turn over and crank. I will try a new CPS.
        #AZE30
        1991 318i
        1989 325i
        1989 335i
        • LagunaSecaBlue
          • Sep 2013
          • 360
          I wil give this flowchart a go
          #AZE30
          1991 318i
          1989 325i
          1989 335i
          • LagunaSecaBlue
            • Sep 2013
            • 360
            Went to inspect, sure enough the Water Pump Pulley ate through the CPS wire.
            #AZE30
            1991 318i
            1989 325i
            1989 335i
            • ///M42 sport
              • 3952
              Same issue here!! Stranded right now
              What's weird is no crank. When I reconnect battery I get a irratic idle then dies and no crank again.?
              Stomp test 1444 = no issues haha
              • Chessmaster
                • Jun 2012
                • 501
                Yeah, I tend to zip tie it off for that same reason.
