Windshield wipers...
    My wipers have been acting up lately, they will be working then pause for a few second then start back up. The other day they paused in the middle and never started back up. It must be a loose or bad connection somewhere. Is there anything i can tighten or clean the contacts of the switch maybe? What do you guys think?
    -Weston
    This problem crops up on a regular basis over here and is usually solved by replacing the actual motor itself, before doing this though, try replacing the relay, it's the big long one. Mine used to do this only on intermitent setting, would work fine on the rest of the settings, I cured it by replacing the motor.
