my 325e has a costant problem w/ the powersteering pully too close to the radiator hose and it keeps on rubbing it eventually punching a hole into it... i replaced the hose thinkint that maybe it was stretched too much... but is there anyway i can fix this??? and who has had to deal with this dilemma..
powersteering pully too close to lower hoes
yeah i still have that bracket... but its not doing a really good job of holding it out of the way... i think the motor mounts are... i dont know, i rev the shit out of it and it only moves soo much... but i guess its still clipping it... can i use an alternater belt to substitute for it??? i think their shorter..13 ph15h c1g4123tt35Comment
I can almost gurrantee you that your mounts are done...
My first autox left me with the very same problem and a big puddle under the car, the mounts break, the motor shifts over to that side and takes the lower hose with it...
invest in new mounts
OR
drill out your rubber and throughbolt the mounts makes it stronger than the original 2 studs...
I have also devised a wicked m42 mount using the same principle ;) but remain stock in appearance muahahaComment
My god, that exact thing happened to me on the highway... the pulley burnt a hole right in the lower radiator hose... lol it suxRecent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
you could take the belt into a parts store, they can measure it, and you can buy a shorter one by intervals of a half inch i believe.Originally posted by DaNDon't think the alternator belt is going to work, its about 140mm longer.
Are you reving it under load? usually the mounts break and bring the pulley closer to the hose.Comment
Listen to the help you are being offerred!!!!
Your motor mounts are more than likely broken- it's a common problem. Fix the mounts and you won't have this problem anymore.
Why make it more difficult than necessary??? If the mounts are old and/or broken, only good things will come from replacing them- DO IT!!
Bret.Comment
