Rear Defroster Wiring - Need input
    One of the PO's has cut the speaker wires and the defroster wires in my '84 eta. My question is, where do the defroster wires go? I see one connector on the lower driver side section of the window. Where does the other wire go?
    90 325i DD/Track
    03 Durango 5.9
    Originally posted by e30mpg
    It is recommended to get new gasket but this is R3v and we just copper spray that shit......slap biotch on and tighten to tq.
    I think the ground is on the passenger side - the wire on the drivers' side is the power wire (I think). I've seen setups before where the defroster grounds out on the C pillar too (again, passenger side), so look around there I guess.
      Thanks! I found the connector on driver side of the window. Did not see a connector on passenger side (hope it didn't break off). One of the PO's did a severe hack job on this car in many places.
      90 325i DD/Track
      03 Durango 5.9
        Not sure if that's a bad thing or not - checked my car after I made my post, I've got a tab on the passenger side too. Granted, my car is three years newer, but I don't know if that would really change the setup.
        Worst case scenario, if you're kick ass at soldering, you could solder a wire to where the clip would've attached to or something. I imagine the bitch level will be at max for a project like that.
          I just replace the entire front air spring/shock/control arm setup on my wife's Allroad... and rebuilt the air pump for that system too... in a one car detached brick garage... in the coldest winter I can possibly remember. This will be cake, like Trina drifting around a big a$$ rock into a house cake.
          Thanks again.
          90 325i DD/Track
          03 Durango 5.9
            That's not on the bitch level scale, clearly you're a masochist ;)
            By bitch I guess I meant you'll have to work in the cramped spot between the glass, speaker deck and C pillar, all while trying to make solder run 'uphill', with the whole solder part being the bitchiest. Never had to make a soldering repair like that, nor do I want to.
            You should take some pics of the repair, should be interesting to see.
              Haha, yeah, that Audi is terrible to work on.
              Yeah, I understood what you meant and chose to deflect because I don't like soldering. We'll see if my 15 year old $10 Radio Shack iron is up to it.
              90 325i DD/Track
              03 Durango 5.9
                So apparently there's a dielectric glue/epoxy out there that some auto parts stores carry specifically for defroster repairs. Not sure if it's shit or not, but I guess good to keep in mind if the whole soldering uphill thing doesn't work out.
                  I got dis, hang on...
                  BAM
                  Current_SeeDee 1972 e10 Luna 1975 e10
                  Past___Veronica 1994 e36 Le-Ah 1987 e30
                    Awesome, thanks.
                    90 325i DD/Track
                    03 Durango 5.9
                      Sure man, happy to help. I did a bunch of research on that whole issue, figured it would help others.
