AC Dismantling
  • jflower
    • 262
    AC Dismantling
    Pulling my motor this weekend, and i'll want to pull the AC system shortly there-after. Who's done it? i know some people sell their refrigerant, but I'm not worried about selling the R12. I'm worried about freezing my arm off.
    Any hints?
    king of bad decisions.
  • Jordan
    • 12911
    just bleed both valves, they are just like bicycle tire valves. Bleed them with a flathead screwdriver or something.
    It isnt THAT cold thats its going to freeze your hand. Wives tales....
    After that its simply disconnect the hoses, and pipes. The take the a/c compressor and bracket off the block.
    https://mtechniqueabs.com/
    • jflower
      • 262
      Awesome.. thanks.
      • Red325es
        • 140
        When you take out the condenser, please wear a breathing mask. I had quite an experience In my garage with ac oil, involving an almost instant bloody nose, extreme headaces , and dizzyness. and my garage smelled like that oil for a long time. Also be discrete about releasing freon into the atmosphere as it is about a 250,000 dollar fine!!!! oh well it's not like anyone would know, unless you have an E.P.A agent living next door.
        Just be sure to use a face mask!
        • matt325is
          • 409
          Do as they said, and dont inhale the freon. THey will have to hang you upsidedown to get it out, it sinks, by the way, to the bottom ofyour lungs.
          matt
          • ydubbs4
            • 275
            Whats the big deal about paying an out of the way garage $20 to recover it for you? This way the environment stays happy, you dont die, and there is nothing to worry about when taking apart the system. Christ, if you cant afford the $20...you got bigger problems then taking the A/C out of your car.
            • jflower
              • 262
              the problem is, my car doesn't move, and it's kinda an ordeal to trailer the car as the only trailer i have access to is a 48' enclosed triple axle. if i could just drop by a local shop with ease, have no worries this wouldn't be a thread here.
              i'm just trying to weigh the options. the A/C needed a recharge anyway, so i'm not sure how much freon is in the system. i'll see if i can borrow an open car trailer and do it that way.
              edit:
              perhaps to keep my hippie roots from crying out, i'll just leave the A/C compressor hanging in the car until i trailer it to my friend's welding shop. no problems.
              thanks for the input guys.
              • OreoGaborio
                • 1285
                just check those valves on the passenger side of the car... i checked mine, the system was empty... out she came 8)
                -Pete
                LRRS/CCS#187 ECK-Racing, Ironstone Ventures, Tony's Track Days
                Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | RJ's Motorsport | Motorcycles of Manchester
                The Garage: '03 Tuono (Hooligan bike :naughty) | '06 SV650 (race)
                • ydubbs4
                  • 275
                  jflower....sorry bout that. Had I known your predicament, I would have left that last sentence off. Best of luck with it.
                  Will
                  • jflower
                    • 262
                    no worries 8) ...
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      It is kind of irrelevant now that you are not pulling it out, but don't the bolts that hold the AC pump bracket on go into oil passageways? So, if you pull the bracket, all your oil will drain out of your engine? Not a very good thing IMHO.
                      Andrew
                      • Jordan
                        • 12911
                        Andrew
                        No, they don't. Alot of people think they do, but they don't
