e36 to e30 oxygen sensor screwjob
  • E30volk
    • Oct 2013
    • 24
    Hey guys, hoping you can help me fix my mistake here.
    I went to replace my oxygen sensor with an OEM bosche one about a month ago and realize that the rubber boot on the connector, on the harness side, had been torn apart by a PO and left the wires and pins exposed to the elements. Everything was corroded and rusted and the connector was basically shot. So I went to the Wreckers looking for another one, but unfortunately E30's aren't very plentiful around here and they didn't have what I needed. But what they did have was an OBD1 E36, which uses the same 4 pin oxygen sensor/connector as E30's, but with different wiring colours.
    Last night I got around to getting it all hooked up. Aaaannd I screwed it up. Basically the OBC says that my mpg's go up as I'm idling and down as I'm driving, and it is running a bit rich
    Here are the wires I connected:
    (e30 loom>e36 connector)
    green/blue>green
    brown>black
    black>yellow
    brown (shielded)>brown
    Here's some info I found on some other threads/forums:
    For an E30, signal Black, Heater Ground Brown shielded on harness side (white on sensor side), +12V heater power Green/W harness side (White sensor side), Signal Ground brown harness side (Grey sensor side).
    For an E36,
    Pin 1 (black) - DME (pin 71 - voltage signal)
    Pin 2 (yellow) - DME (pin 70 - ground)
    Pin 3 (brown) - Ground (shielded)
    Pin 4 (green) - O2 sensor relay (power)
    So, does anybody know which wires I need to connect? Anybody done this before or any swap wizards know what's what on both e30 and e36 harnesses?
    Cheers
  • AndrewBird
    The Mad Scientist
    • 11898
    Well, from the info you posted, it should be:
    E30 - E36
    Black - Black
    Brown - Yellow
    Green/Blue - Green
    Shielded Brown - Shielded Brown
    You have the e30 brown and black wires mixed up.
    • E30volk
      • Oct 2013
      • 24
      Thanks! Got it rewired and all is correct now
