1988 supereta wont start.
  • superboosted
    • May 2012
    • 667
    So no spark, no fuel.
    -checked timing belt
    -checked and swapped cps-(488 ohm at rest)from m30
    -swapped fuel pump/main relay on strut tower
    -check fuse in line on positive cable
    -just cranks and cranks.
    Have a whole IS for parts swapping(m30 swap going on)... been searching for 2days. Need this car for dd. Ran when parked.
    Please point me in the right direction.
    No spark and no fuel will be:
    No timing data to the DME
    A DME power/ground problem
    A bad DME
    • superboosted
      • May 2012
      • 667
      Can i use the DME from my 88325is? Is the cps the same from a 91' m30?
      • superboosted
        • May 2012
        • 667
        Ok..I'll try that later..
        • superboosted
          • May 2012
          • 667
          Swapped ecus. No dice. Read about half the Bentley manual and no answers there either. ����
            I don't know if the CPS from an M30 is the same. Get a new OE CPS, not some off brand.
            • superboosted
              • May 2012
              • 667
              Well I have a known good one from my other m20 car I can try, any differences between 325/325is sensor? Same build date 11/87 :)
              • Overlord475
                • Dec 2010
                • 799
                Check crank position sensor:
                http://www.pelicanparts.com/catalog/..._pg1.htm#item2
                A timing light is a great tool to have laying around too (HF FTW!)
                --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
                • superboosted
                  • May 2012
                  • 667
                  I have a timing light but how does that help in this situation?
