In need of serious help
  • shayne_bermudez
    • Nov 2013
    • 78
    My project 318i is literly mind fucking me . I can remove my key from the ignition and it still is running....i pull the #10 fuse amd start it boom everything shuts off like its suposed to. the top wire on my starter (green and black) will heat up like crazy and idk why. Please explain why these are happening. ANY HELP IS MUCH APREICIATED.!!!!!
    I HAVE PICTURES I CAN EMAIL AND TEXT YOU MY NUMBER IS 8607970887
    E30s for life. will drive nothing else than a BMW.
  • deutschman
    • May 2008
    • 5958
    What have you done to the car? Did you rewire something, and if so what?
    • shayne_bermudez
      • Nov 2013
      • 78
      The cluster was acting up so i taped up my reverse light wireing ( wire that runs from shifter boot down by the drive shaft and to the tranny) that fixed my cluster but the starter was before all that. I replaced the starter when i first got the car idk if that may be it. Also idk if i have a parisitic drain or if its the starter thats sucking up the battery life
      • Poorboyz
        • May 2012
        • 2117
        Sounds like something in starter is wired wrong.
        Rebuilding since 07/06/2016
        Poorboyz Parts For Sale - Updated 01/20/17 - Will be updated soon - Have many parts to post
        Poorboyz Feedback Thread
        • shayne_bermudez
          • Nov 2013
          • 78
          Like i need a new starter? I have a spare one but the bolt holes are broken so i can mount it but its good for parts
          • AndrewBird
            The Mad Scientist
            • 11897
            Sounds like a bad ignition switch.
