So I felt productive today and decided I would replace my clutch slave cylinder and the rubber line that goes to it. Have had the parts sitting around for a while, and the clutch pedal has been resting on the floorboard since I bought the stupid car; if I ever wanted to move the car out of the garage without pushing it, this job needs getting done.
So I looked at Pelican's article here: http://www.pelicanparts.com/bmw/tech...utch_Slave.htm
Looks easy enough. Well getting the top nut off the slave is a task in itself combining deep sockets, extensions, and ratchets with flexible heads. Got that done, looks shot, super. Now for the rubber line. Well I get my flange wrench (line wrench, whatever they're called) and twist the 14mm nut on the end of the rubber line ( Item number 20) that attaches to the hard line. Well the drop light I was using did not illuminate the fact that clip 13 was broken, so as I twisted said nut, it was twisting hard line 10 into a curly-Q. Although I'm pretty sure I didn't bust it, I think I'll source a new number 10,11, and 13. Take this as a precautionary tale.
