blower motor clip
  • jrobie79
    • Mar 2006
    • 2526
    blower motor clip
    i finally got that clip on so i put the covering on and test it out to see if it rubs so i can adjust it and i hear it hitting something so i take the cover off to see that the clip came undone by itself, whats the deal with that do i need a new clip?
    1991 318i ---- 308K - retired
  • jrobie79
    • Mar 2006
    • 2526
    bump
    • Bimmerfanatik
      • May 2004
      • 5349
      Probably a safe bet - try re-clipping it again and see if it comes off again. If so, replace the clip - can't be more than a buck or two.
      • PeaveyBassist
        • Sep 2004
        • 3511
        This clip is a pita to put in. I recommend setting it on the blower motor before you drop it down into its little groove then rotating it back and just jiggle it around a lot until it gets in where its suppose to be.
        Depending on which blower motor you have... (from realoem.com)
        Shackle - 64111375620 $3.35 (long skinny blower motor with 2 rows of fins on each side)
        Shackle - 64111370935 $3.35 (shorter blower motor with only 1 row of fins on each side. You prolly have this one)
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
