s50 will not bleed
    Yeah im callin it, its a bad HG. The pressure test wasnt great, just tried to bleed again and overheats instantly tons of air in the system. Also now the engine is stumbling badly probably from a leaking HG getting worse from repeated over heating.
    Great. Should have just sent it to the machine shop in the beginning. O well, im out about 300 in oil, coolant, thermostats, gaskets (which i will now most likely have to replace again) and unfortunately considerable time.
    94 325is
      You could test for a head problem by doing a leak down test with 170-180psi air. But there is really no need to do so. The coolant fountaining out of the overflow tank when you rev the engine is sufficient proof.
        Thanks for the help the machine shop is getting me a quote on a rebuilt bottom end/hone/re ring and checked out/resurfaced head on monday.
        94 325is
          Sorry to here that it didn't work out.
          I guess I got lucky with not having to tear mine down. Crossing my fingers, it has been running for over a year now.
          I hope you get yours running soon!
          1988 325 non-letter Seta "Bronzit"
          1991 325ic "Laguna Green" (Sold)
          1993 325i "Laguna Green/Silver" (Sold)
          1998 528i "Artic Silver" m-sport(totalled by drunk driver)
          2000 528i Titansilber/gray m-sport
          2000 528i Titansilber/black m-sport(sold)
          2001 525i Anthracite m-sport(sold)
          2013 750i Black/Black m-sport "Beast"
            Well, it turned out to not be the head gasket. (I still am paranoid though lol) I was literally about to pull the head and i realized that you e30 guys convert the coolant temp sender to the m20 one which will not work on the e36 gauge - makes it read high.
            So i slapped in a new m50 temp sender, and away i went.
            94 325is
