So my car has recently developed a drivetrain vibration that sometimes becomes more severe and turns into a thumping noise.
Speed has no effect, throttle input (accel/decel) has no effect, clutch engage/disengage has no effect.
When I first noticed it I thought it was my right rear tire. Cruising at around 55mph, pull over, check the tire, no sign of anything abnormal.
The noise comes and goes, sometimes minor vibration felt through the seat. Other times its a severe thumping that makes me want to slow down.
The car is an s50 swap with all new guibo/csb/rebuilt driveshaft/bushings etc.
My thought is that the driveshaft could have been mis-balanced causing a pre-mature CSB failure.
Could a bad CV-joint cause this? I noticed the clip on the CV boot is missing, possibly letting in water/salt/sand while dropping grease.
This is all I've got, thanks for reading, any help or question appreciated.
-Scott
-Scott
