Doing a great deal of undercarriage maintenance.
Some parts being replaced with new. Some parts will be reused.
Wanting to kill/retard/stop/prevent rust on parts upon installation. Nothing show room - just effective prevention.
intended procedure:
1. De-grease/de-rust/clean up
- intending to use WD40 & degreasers like Simple Green for initial cleaning
- intending to use sandblasting, wire wheel brushes, and sand paper for ‘de-rusting’
- also using a product from hardware store which claims to 'chemically kill rust'.. (like a rust-killing primer(?))
2. Use chemical solvent product for oil/soap removal prior to painting
- allow to dry or blow dry w/ compressed air
- handle with rubber gloves on
3. Use various rattle can paints/coatings on parts (high temp paint for heat shielding & brake components – rubberized undercoating for body areas - rust inhibiting paint for other misc hangers, clips, ect)
- allow to dry
- install
step 2 is where I’m mainly asking for advice.. what’s best ‘pre-paint’ chemical? Mineral spirits? Lacquer thinner? Paint thinner? Acetone? Denatured alcohol? - so many to choose from..
Advice/input appreciated. tia
intended procedure:
- allow to dry
- install
