Pedal Box Replacement
  • EyExR
    • Jan 2011
    • 959
    Okay. So my pedal box has a small crack in it -which, I believe, may be causing a low clutch pedal.
    I have a manual, airbag car. What's the story on replacing it? Do I have to pull the dash? Any details would be VERY helpful. I'm hesitant to even start this job.
    My 325iX DIY Threads:
    Front Wheel Bearing Replacement
    325iX Rear Subframe Bushings and MUCH more w/pics!
    325iX Steering Rack Replacement, Suspension, & Oil Pan job w/pics!
    Depending on where the crack is, it might be possible to weld the crack w/o removing the pedal box.
    • EyExR
      • Jan 2011
      • 959
      Yes, I thought of this but think it best to replace entirely. I don't trust myself with a welder up in there... nor would I trust anyone else at this point.
      Also, I think once the box has cracked it'll never be right. I have a brand new one on hand....
      So, anyway, what's involved?
      • FredK
        • 14763
        I just removed an airbag pedal box yesterday in a car that had no dash.
        I am 99% certain it can be done with the dash in place.
        The vanity covers first need to be removed, as well as the lower steering column panel. You then have to lower the steering column by removing the two anti-tamper M8 fasteners that secure the column to the sheetmetal bracket of the car. This will likely require slotting with a Dremel or similar tool, then removal using a screwdriver. Beyond that, there's a single M8 bolt that secures the column to the pedal box.
        You will have to then remove the pedals from the bracket. This is held in place with a long M10 bolt. You must also remove the brake pedal from booster clevis. The booster nuts must be removed (4x M8). You then need to remove the four M8 bolts that secure the pedal box to the sheetmetal of the car.
        You should be able to remove the box now.
          I would not hesitate to have a pro weld up the crack. A real pro will tell you "no problem" and take the precautions needed to avoid damage to other things. Or they'll decline the job.
          • bmwm42
            • 6300
            You do NOT have to mess with the steering column. I've done this plenty of times
            Originally posted by bmwm42
            PNW vulture pm me for parts
            Strategic nw e30 command
            • FredK
              • 14763
              Oh, yeah I guess if it's possible to remove the two rear-most M8 bolts, you don't have to necessarily drop the column. I just didn't see a way to get a wrench in there.
              • roznic
                • Mar 2013
                • 2880
                Definitely can do it without touching the dash!! just gotta have the right extensions and swivel extension will help.
                • EyExR
                  • Jan 2011
                  • 959
                  This helps a lot! Thanks!!
                  I'm assuming this would be the same on an iX with airbag..
                  • SmokeE30
                    • 1730
                    Don't assume anything with an IX but I know the clutch pedal itself is interchangeable on them when adding the clutch pedal to 5spd swap an IX so they are probably pretty damn close if not the same
                    Shawn @ Bimmerbuddies
                    Bimmerbuddies LLC
                    717-388-1256
                    2971a Roundtop Rd, Middletown PA 17057
                    bimmerbuddiesllc@gmail.com
                    • EyExR
                      • Jan 2011
                      • 959
                      I'm mostly concerned with airbag vs. non-airbag.....
