Help w/ E30 CEL
  • goldfishe666
    • Feb 2014
    • 107
    Help w/ E30 CEL
    Hey guys I have a 1991 325i M20B25. I did an oil change and wanted to reset the oil service light.
    It was late at night and i jumped the wrong pins.. After I realized why it wasn't working, I jumped the correct pins and the lights reset.
    However while jumping the wrong pins, I believe I made the car throw a CEL. I know there wasn't a CEL prior to that as I had a smogged recently before that day.
    Instead of jumping pins 7 and 19, I jumped 7 and 20.
    Any way to fix this or something? I am selling the car soon.
    Thanks a lot guys
    Edit: I am currently located in Davis, if anyone is near there or Sacramento has a scanner I can use I would really appreciate it.
    You could try a hard boot of the DME by disconnecting the battery for 30 seconds. But if the CEL returns the grounding of pin 20 has damaged the DME. In that case a replacement DME is the fix.
    • goldfishe666
      • Feb 2014
      • 107
      Ive had the battery removed a few times for longer than 30 secs. So is DME the same thing as ECU?
      • TurboJake
        • 3780
        Yep.
        Leave Me Transaction Feedback
        • MoreMayhem
          • Feb 2012
          • 650
          1991 should have a 173 or newer DME. Do a search for 'stomp test'. It will show what error is being detected.
