Drivers Side Rear Light Cluster Not Working
  • nvbass
    • Oct 2013
    • 11
    I have a 87 325i vert and none of the drivers side rear lights work; no turn signal, brake, reverse lights, etc. The dash light blinks really fast if that helps, as it should i guess. The right side works fine as does the center light on the rear spoiler. Bulbs are new so anyone know what else to check?
  • goldenbb
    • Jun 2013
    • 208
    Check the round connector that plugs into the tail light assembly. It has a bunch of male pins on it and those can break off or otherwise lose contact. Or you have broken wires in between front and rear somewhere.
    '90 zinno 325iS
