88 325ic obc reads blank
    i just did timing belt and changed all gaskets and hoses and parts that you take off or near of the car. e.g camshaft gasket & crankshaft gasket w/ intermediate gasket oil pan gasket etc..
    Anyways, in the process i steam cleaned my engine bay and under. As of right now my obc reads blank. But it was reading perfectly find prior to. my check panel also states few things are low. coolant, engine oil washer fluid. but prior to everything else was working. i stayed away from electronics and if not, i had something covering over it. On the side note i must state that if i dont use the vehicle daily, my si battery(s) will die and my tach and my coolant temp will have incorrect readings. when i did my steering rack swap it stated my oil light was on from the check panel but within a day or 2 it went away. Any places to check or techniques to make them all work again? i check the faq and some forums and well, its a hit or miss with the over check panel, but the luxury of a perfect working obc and check panel, felt great. thanks for reading
