p/n verification
  • jrobie79
    • Mar 2006
    • 2526
    p/n verification
    can someone verify if part #2 is where the driver side headlight brackets screws into...this would be the screw that is furthest to the right if facing the car. (there are 3 total mounting screws for each headlight bracket):
    I got in a front end accident and the headlight got smooshed in a little bit, bending that metal piece, its welded to the body of the car stock.
    1991 318i ---- 308K - retired
  • jalopi
    • 2370
    Sounds like a pain in the dick to chop out and weld in. If it's only a little bit smooshed why not bang it straight again with a slide hammer or something?
    • jrobie79
      • Mar 2006
      • 2526
      its completely flattened...I'll weld it in as best as I can, the existing won't be too difficult to get out with a grinder/air saw
