I was just finishing up putting my interior back together got the lower drivers kick panel back on and each side kick panel on started the car and the Tach and MPG guages now do not work, they worked 10 minutes prior to this i checked the fuses and i have none blown, i removed the cluster, removed all connections and reconnected everything reinstalled cluster, still no tach or MPG, disconnected battery still no tach or MPG,, Is there any wires or connections under the steering wheel above pedals, by the ECM that i could have touched or fucked up that would cause this problem?
temp and fuel work i have 5 green lights on the service indicator check panel works Check engine light does not work and never has since i owned the car.. not sure what do to here it was literally just working then 10 minutes later after installing the kick panels it doesnt work, WTF 27 year old bmw!!
i also tried getting my central locking fixed today, i tried disconnected the drivers side electrical plug that goes between the door and the body that has the reubber seal cover it in the door jam, yea i found it impossible to disconnect this connector infact some of the side edge piece that the rubber grommet goes under has broken off because it was so brittle, i ended up leaving it alone, now my central locking works o.O but tach MPG dont, i dont think this has anything with tach mpg unless some wires for the gauge cluster end up going through the drivers door o.O
