HELP! Bolt extractor broke off inside CAB bolt hole
  • ebox86
    • Sep 2012
    • 528
    So im in a bit of a pickle. I had a bolt break inside one of the CAB bolt holes on the drivers side CAB. The one is fine but the outer bolt broke inside the hole. Well now after trying to extract it, it seems i've used the wrong size bolt extractor and now the extractor is broke inside the hole. From my readers, these extractors are made of hardened steel
    Some people on other forums have suggested a bit made of carbide. I went to depot today to try their hardest titanium bits and the extractor just laughed at it.
    Heres a pic of the damage
    Any suggestions?
    '99 e46 323i - wrecked
    '87 e30 325iS - sold
    '91 e30 325i - sold
    '89 e30 M3 - fun car
    '09 e91 328i - sold
    '97 impreza - rally car - flipped
    '08 impreza - new rally car
    '01 996 tt - more fun car
    '82 Ford f350 - work truck
  • berlow94
    • Jan 2013
    • 1063
    McMaster carr
    The best one-stop shopping for German car parts and lifestyle: http://www.gutenparts.com/
    • ebox86
      • Sep 2012
      • 528
      any particular type of bit i should get? Just a quick search on their site and found this :
      McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
      '91 e30 325i - sold
      '09 e91 328i - sold
      • ebox86
        • Sep 2012
        • 528
        I found these but wasn't sure if this would work, has anyone had first hand experience drilling into one of these?
        '91 e30 325i - sold
        '09 e91 328i - sold
          Yep you need a solid carbine drill. And it should be a left hand twist as that may back out the bolt stub as you drill.
          • Wanganstyle
            • 2828
            You could try applying heat and making a slot for impact screwdriver. Sears or a auto parts store should have it.
            heat expansion will let the threads and bolt separate a bit.
            • meanEG
              • Oct 2013
              • 562
              if you decide to cut the welded nut out i think i have a good frame rail section with a good set of them in there. you could cut a hole in the side of the rail and air chisel them off weld new one and reweld and seal.
              Looking for late model fogs, E39 Fog lights, cool cheap 17 5x120 wheels.
              • ebox86
                • Sep 2012
                • 528
                I think im going to try heat with a blow torch to try and expand it and then knock it loose, carbide bit is on order tho
                thanks guys
                '91 e30 325i - sold
                '09 e91 328i - sold
                • FLG
                  • Sep 2011
                  • 3165
                  Do you have access to a welder?
                  Could just weld a nut to it then use a socket or wrench to remove it all.
                  -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                  • blusylver
                    • Feb 2013
                    • 230
                    This.
                    I have had to remove several broken extractors. I would take a Dremel and try to get the extractor as flat as possible. Also I had a set of left hand diamond tiped drill bits.
                    Also if your using the twist style extractors, do yourself a favor and throw those away and get the straight flute extractors.
                    • trkadct
                      • Apr 2009
                      • 19
                      I had a similar situation, minus the easy-out breaking off. I drilled out the bolt, ground the threads off a stud, hammered it in, then welded the circumference.
                      • ScHpAnKy
                        • 1573
                        Ran into the same issue last weekend, I got a beefy screwdriver roughly the size of teh whole, hammered it in, finagled the screwdriver into a 18v DeWalt drill and the bolt screwed right out with one punch of the trigger. YMMV, but it was really in there so I think that method should be a first shot
                        91 318i | 87 535iS
                        • Liquidity
                          • May 2014
                          • 395
                          Drills are not made of titanium. Even if they were titanium it's not harder than carbide or regular drills. Quite softer. What you bought are just regular old drill bits with titanium nitride plating (that gold stuff on them).
                          I suggest you just try the welder method if you haven't figured this out yet. Carbide bits are very expensive and they chip and break very easy if you don't take extreme care when using them.
                          • Aleman
                            • Mar 2012
                            • 1597
                            Take it to a shop. I broke off a front subframe bolt once, spent $200+ on tools, and ended up paying to get the bolt extracted by a pro. Same thing when I broke off the small bolt at the back of an M20 head where the water pipe attaches. Had to get it extracted at a shop. Broken bolts are HUGE pain in the ass. I feel your pain.
                            R135 /// 1990 Alpinweiß II 325is
                            └┼┼┘ /// 1993 Black/Black Convertible (sold)
                            ..24
                            • bavarianbrawler
                              • Feb 2013
                              • 33
                              McMaster Carr - reverse-thread carbide drillbit so when you're drilling out the bolt it has a chance of grabbing and unscrewing it. Otherwise, it'll chew through the bolt easily. Penetrating oil before and during.
