Tranny seal replacement
  • blueapplesoda
    • Dec 2005
    • 1904
    How do i change the input/output tranny seals? do i need any special tools?
  • Old'n'Slow
    • 436
    I wouldn't fool with the input seal unless it's leaking. Major pain+possibility of damaging the seal housing.
    The output seal requires a thin wall 32mm (I think) socket to fit inside the flange to remove the big nut then pull the flange to get to the seal. Bentley has a good procedure for this.
    Don't forget the selector shaft seal, too.
    Good luck.
    • DaN
      • 1265
      30mm thin wall deep socket, kinda hard to find
      I second the selector shaft seal.
      • RobertK
        Kicked cancer's ASS.
        • Jun 2005
        • 5864
        It's cheaper to buy an 30mm impact deepwell socket and grind it down until it fits.
        • Old'n'Slow
          • 436
          That is precisely what I did except for the "impact" part. Non impact takes less time to grind!
          • T.Dot E30
            • Mar 2004
            • 536
            I tried that and it cracked.
            I believed i ended up forcing a socket on with a hammer :D
            It worked, lol
            • Simon S
              • Oct 2004
              • 3758
              Pelican article including selector seal
              Good output seal article
              just recently replaced my seals
              $35 tool (Bavarian) - $9 seal
              three jaw puller for output flange
              removing output seal
              removing selector seal (took some patience)
              -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
