My power mirrors suddenly stopped working, and they won't heat up anymore. This was after I had taken the door panel off to fix the window regulator. I took the door apart again and gave everything a cursory check no bad wires that I could see, and checked all the fuses. No cigar.
Checked the voltage at the switch connector, I only get a potential difference between connector 4 (ground?) and connector 2. I'm assuming this the left/right swap switch?
Im gonna go with bad wiring... Anyone have a wiring diagram thatll include all the stuff in the door and where the wires leaving the door lead to?
Finally, why would all this affect the heated mirror feature on the car?
thanks
thanks
