Hey being that there was a debate going on about stock injectors only pushing out 13lb/hr or 14.5/hr but no actual proof I decided to find a source that we can all profit from. I'm not here to debate but instead just provide a piece of info
There's two web based sites to visit I want you to check out:
This is a site that will not only give you all your specs for all Bosch type injectors but even gives you an injector calculator,info on injectors(how they work) and they'll even clean then up for you! No more guessing guys!
And
This website helps figure out(for the most part) which injectors originally were installed as a stock unit or at least that's what I use it for.
The part number for the bosch injectors maybe be on the sides of them. 8 digit pn
Thanks and good luck !
And
