I believe I need a new aux fan low speed relay, because no matter how I jump the pins in the sensor, I can only get it to run on high. Also, there's nothing wrong with the blower motor (knock on wood) and it works on all four speeds. I also think the system might not be charged after all after checking it out with a friend who has a gaugeset. There aren't any other R134a parts on the system aside from the screw-on connectors at the high and low-side ports
I'm not too smart, but by looking at the wiring diagrams, I believe my issue to either be the Evaporator temperature sensor, or the evaporator temperature regulator.
Is it possible to jump the evap temp sensor momentarily to see if the compressor kicks on? Do I need refrigerant?
--Mike
--Mike
