I was trying to change the crank sensor and my feet slipped on the gravel when i was tightening it and leaning over the fender and i ended up stripping the threads on the bracket that the crank sensor 5mm bolt bolts to. Anyone have an idea on what i can do to repair it? does that bracket come off the motor easily? i couldn't get in to see if it does or not. thank you in advance for any input! first post so i haven't filled out anything but the car is an 87' 325is with the M20B25.
stripped the bolt that holds the crank sensor
