brake pads?
  • rede30
    • 4697
    brake pads?
    i changed my front brake pads awhile ago and not the rotors,b/c i didnt think they needed them, but now like 2 months later my front brakes grind like hell. if i just put new rotors on will i need to put new pads on to, or will the pads work ok.thanks alout
    dustin
  • 318daily
    • 507
    pads should work just fine if you grind the rotors. I was getting vibration while braking and just did the rotors while keeping the same pads and it all worked out fine.
    • rede30
      • 4697
      thanks dude, would you recemend spending alittle more and getting like crossdrilled or slotted rotors, thanks agian
      dustin
      • DaN
        • 1265
        If your front brakes grind, then most likely one or more of the pads has worn down to the metal. Therefore they need to be replaced.
        I would recommend getting some drilled or slotted rotors if you often encounter brake fade, if not, oem stuff should work just fine.
        Be sure to scuff up the new rotors, and clean them up with brakeclean before installing. This will help the pads seat better.
        Also, it's imperative that the caliper sliders are moving freely. Use some anti-seeze or caliper lube on them, to keep them free.
        • rede30
          • 4697
          thanks, i just did the front pads, and i just checked and made sure they are good and they have lots of life left. i am going to get some rotors then put the caliper glid stuff on, i know what yoru talking about. thanks again.
          Dustin
          • DaN
            • 1265
            If the pads are good, What was causing the brakes to grind ?
            Do you mean pulsate?
            • rede30
              • 4697
              no they were grinding pretty bad, i was surprised to take off my wheel and still have pads, i have a steep drivway and towards the bottem i didnt even want to knwo what i had done to brakes, i have been braking less hard, but i can still feel a bit of grind. it almsot seems to not be as bad though, i will let you know
              • e30Matt
                • 5077
                Yes, define "grind." Do the brakes do it all the time, or just under heavy braking? If it's just under heavy braking, that "grinding" you hear may be the ABS kicking in. If not, check your rotors.
                • DaN
                  • 1265
                  Did you look at all the pads? the ones on the inside, and the rear?
                  • 318daily
                    • 507
                    Just clarifying what I meant by "grind". I was referring to turning (i.e. resurfacing) the rotors.
                    I would stay away from cross drilled rotors. I'd either get slotted or stock rotors.
                    • rede30
                      • 4697
                      well for about 2 days straight they were grinding on somwhat hard braking not to hard, but tonight comeing back from my girlfriends house i hit the brakes hard to see and they were perfect, i have no clue what went on. and yes i checked the inside and outside of the pads. i will see how they do for the next few days. and to define the grinding more, it is hard but to describe but when my pads were really low last time and before i changed them it felt jsut like that. like there is low pads, but i dont know i am confused. peace out
                      Dustin
                      • James325sport
                        • 18
                        My front n/s grinds as well I have taken them apart and pads and rotors are fine, but will change the pads at the weekend anyway and see if thay are any better.
                        325i Sport
                        • darien28
                          • Jan 2004
                          • 240
                          i need to do my brakes as well.
                          the last time I did brakes was ummm... a long time ago before I got my rims... must have been like 3? or more yrs ago. back then I was stupid... I used all new ate blanks w/ the worst choice in brake pads ever... OEM dealership Textar fronts and PBR metalmaster rears... and guess what... now I need new rotors again since my rotors are all eaten up and beyond repair I think...
                          this time around I got Ate powerdiscs in front and ate blanks in teh rear.
                          as for pads, I HATE dust on my white wheels... so... at first I wanted teh hawk pads, but they don't make a rear fitment, and I don't want unbalanced friction on front and rears cuz that would just lead to uneven braking and/or premature pad wear/overheating/etc.
                          so my next choice was Pagid blue from truner... then I read the break in procedure... 9mph->65 at 400-500degC then blah blah blah... too complicated and I don't wanna do 90->65mph runs on the street.
                          then axxis ultimates, but ppl say they dust a bit.
                          so finally, I chose ebc green stuff pads form tirerack. they're on their way, and I'll have the brakes in next week sometime. I'll also be painting my calipers a nice blue color. ^^
                          I'll let you all know how tehy feel. I also have SS lines and the 25mm master cyl from a 735.
                          BTW, my brakes make a whooshing sound when I step on them... ?? WTF is that? I bled the system 2 times with over 1 liter of fluid.. so there's no bubbles... ow ell. I've just been living with it for the past 2 years, so whatevers.
