What I found out so far:
I don't want to stroll off and buy a $200 valve, just to see I screwed up and something else is leaking. :)
Thanks for the help.
- Its one of the components of the heater core.
- The car had AC, so its not a monumental job, but I haven't checked yet.
- The coolant is pouring down above the gas pedal.
- The coolant light above my head is on.
- I don't know where to check for the proper coolant level.
- I don't know where to add water/coolant.
- The car is blowing heat normally, and there is no leaks under the car - So i assume that te problem is nr. 16 (http://bmwfans.info/parts-catalog/E3...er/#1386707_16 - the valve
- Do I have to change the pipes too? (nr. 4 and 5?)
- I found this on r3v http://www.r3vlimited.com/board/showthread.php?t=98782
