Hi all,
So I know this question has been asked before, but I am at a loss of what to check next. I have read that these symptoms can be attributed to the 'Unloader Relay'. I have a brand new started just installed from but experiencing no power to the items listed above, hvac, power windows and mirrors. Door locks work, radio works, dash cluster works, and essentially everything else. Yesterday I went over the connections on the starter and confirmed that they are all correct. There are 4 studs. The car is a 91 and starts just fine, so i know its connected correctly.
I have been checking my grounds and all of them seem to be hooked up. I am trying to figure out if anything else could cause this issue. The car is an auto to manual swap but as far as I am aware, it shifts find and parks fine and the wiring is correct. Even reverse light is working.
Any suggestions?
thanks
Any suggestions?
thanks
