Basically my friends who are mostly honda owners have decided they are going to turbo every vehicle they own creating such things as turbo 2000 DX coupes and LS/Vtec Turbo CRXs so I've decided to turbo my 325iC.
I have a CT26 turbo off of a Toyota Supra its a moderate size, I have a DSM sidemount Intercooler I'm placing where my windshield washer fluid tank is <God help me if I accidently hit it with the top down> so I can remove my high beams. We're installing Euro Projectors with City lights and I'm wiring those to come on when I flash my high beams. I have all the piping and a custom exhaust manifold adapter for the turbo.
Now the fun part, I'm assuming I need 19 or 21lb injectors and some form of MSD. My only problem with a MSD is I enjoy my chipped 6900 redline and MSDs usually have a setting for 7000 and I don't think my motor would enjoy hitting that under boost. For my FMU I'm thinking a 5psi increase per lb of boost should be ok will my stock fuel pump support that? I only plan on running 6 to 7 psi until I can do a 2.8 low comp rebuild.
So,
Do I need an MSD with a stock chip?
Anyone deal with those Vortech FMUs if so which boost rate works?
Is there anything special I should know before I end up stranded at the street races because I pissed my M20 off?
I'll do pictures and what not soon.
So,
