sup.new guy onboard...questions on 318ishelp
  • duuuurtymyk
    • Apr 2006
    • 111
    ive had my 91 918is for about 6mths now and i want upgrade a few things in further attempts to better in "spirited driving"...my IS has a few suspension mods, relocated cold air intake, striaght pipe header back no cat. i had a few questions i was hoping a few you could help out with.
    1. whats the ecu code(in regards to purchasing chip)
    2. is there a short stroke setup where i can purchase shorter in stroke shocks.(ie. i did this to my ae86, i cut off 40mm of my strut housing and then put in short stroke adj. kyb agx's from a mr2). i already have custom SPL 10kg and 9kg springs..all i need are shocks, any recomendations?
    3. are after market cams worth the hassle for a daily driven car that gets taken to the track 1ce a month?
    4. how direct is putting in a 325 clutch and flywheel, i want to lighten the flywheel to improve throttle response, but the m42 flywheel is 28lbs! are there other parts i would need to put this im my car....
    thank you in advance.... myk
    http://www.youtube.com/watch?v=JJ707dGNelg
    ...and slide, and slide, and slide
  • Eurospec
    • 2612
    Many of the stuff you're inquiring about has been covered here
    • duuuurtymyk
      • Apr 2006
      • 111
      fuck yea!!!! i soooo needed that..much thankx!!!
