Blown Coilovers?
  • Coltoyup
    • Jan 2014
    • 29
    Blown Coilovers?
    Ok guys i need some help. so i was doing a hard put onto the freeway and i started to hear a knocking noise. i slowed down on the feeder road and the noise stops below 20mph and stops doing turns. when at idle theres no knock. I'm thinking it has todo with the transmission or suspension or wheels. ill get under the car tomorrow morning and see if i can find the source. anything you all think i should be looking for? thanks.
  • JinormusJ
    • 6887
    Blown Coilovers?
    Would help if you described the noise and source exactly where it's coming from
    • Coltoyup
      • Jan 2014
      • 29
      source unknown. but the location it seems to come from is right in front of the passanger firewall
      • ThatOneEuroE30
        • Dec 2013
        • 8626
        Wheel bearing????
        1991 318i 4dr slick top
        Mtech 2 turbo restoration
        • Coltoyup
          • Jan 2014
          • 29
          ill check that but I'm not sure cause its more of a clunking knock more toward the right side center of the car.
          • Coltoyup
            • Jan 2014
            • 29
            it has been raining so ill have to wait to check out the car. hopefully tomorrow.
            • Coltoyup
              • Jan 2014
              • 29
              So i couldnt find the noises source. i am how ever putting in a stage 3 clutch soon so maybe thatll fix it or make the source more apparent. thanks guys that tied to help.
              • Jb325is
                • 2137
                Driveshaft center bearing or broken engine/trans mount?
                - '88 m54 coupe
                <3
