1988 Late model 325is. The car in question has inoperable windows and sunroof. They run under the same circuit which I am aware of, fuse #17. The fuse is 30 amps and is okay. I then tested every switch and the city it breaker and I do not have power. I tried tightening the green wire on the starters and that didn't work. I also switched relays and they all work. This thing has me stumped I have tried everything. I also noticed this upon further inspection in the fuse box: every fuse has connectors for each side except for this fuse (#17) i then proceeded to pull of the top of the box and looked for the wire and connector to see if it fell out from under and there was nothing there. According to the wiring diagram I found, it said it was a green and black wire and I traced that wire to fuse #8 which is the rear window defogger. This car is kicking my ass and I'm stumped I need help ASAP. Thanks.
