Need wiring help!
  • Tylerse30
    • Sep 2012
    • 54
    Need wiring help!
    Hey guys, so I got my car back from the body shop after intensive welding all over the car, when I threw the engine in I had several blown fuses, (even though it had no battery in it at the shop) I replaced all of them with the proper amp and came to the problem where fuse 21 will make or break me.
    Fuse in: brake lights are constant until battery is unplugged. Radio works, interior lights work, tach works,
    Fuse out: brake lights work fine. When brake pedal is depressed the radio/interior lights/tach will work. Let the pedal out and they all become dis functional.
    Also the front an rear parking lights don't work at all. I took apart the harness on the driverside floor under the carpet and found connections toasted so I took some apart and attached them clean. That's what got me this far. Before I had no working tach. Please help me!
